March 17, 2023 at 6:12 amFAQParticipant
In cases where multiple species enter the domain through multiple inlets with one of the species having a flow rate orders of magnitude less than the rest, it is almost impossible to get good species mass balance for the trace species. This is because at the inlet (mass flow or velocity) for the trace species, the mass fraction of that species is set at 1 and 1 cell next to the inlet, the mass fraction is very small. This huge gradient makes it almost impossible to converge that particular species conservation equation. To overcome the problem described above, the work-around is to make that species inlet as wall and separate one cell region next to this wall from the rest of the fluid. Then one can specify mass and species source terms for this one cell region next to wall such that the total mass of species flowing into the domain is same as that specified by the mass flow (or the velocity) inlet earlier. With application of source terms, the gradients are not severe and the flow and species equation converge nicely and overall species mass balance is obtained quickly.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- What is the superficial velocity in multiphase flows?
- Mixing Tank Modeling in ANSYS Fluent
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- What do “incomplete” DPM particle tracks mean?
- Simulation of Exhaust Gas Recirculation (EGR) Cooler with CFD
