May 25, 2023 at 7:29 am
FAQ
ParticipantRadial and azimuthal components of B field can be obtained from the x- and y-components of the field using the following formulas: B_r=cos(phi)*Bx+sin(phi)*By B_phi=-sin(phi)*Bx+cos(phi)*By In Maxwell you get B_r and B_phi using the fields calculator: Radial component (B_radial) Input > Quantity > B General > Smooth Vector > Scal? > ScalarX Input > Function > Scalar > PHI Scalar > Trig > Cos General > * Input > Quantity > B General > Smooth Vector > Scal? > ScalarY Input > Function > Scalar > PHI Scalar > Trig > Sin General > * General > + Select Add and set the name of expression as B_radial Azimuthal component (B_phi) Input > Quantity > B General > Smooth Vector > Scal? > ScalarX Input > Function > Scalar > PHI Scalar > Trig > Sin General > * General > Neg Input > Quantity > B General > Smooth Vector > Scal? > ScalarY Input > Function > Scalar > PHI Scalar > Trig > Cos General > * General > + Select Add and set the name of expression as B_phi
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- How to create and manage a queue of simulations?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- Are solid losses and eddy losses the same in Maxwell?
- How to calculate capacitance and inductance in Maxwell Transient solver?
- How to perform a material sweep?
