Tagged: 15, ANSYS Composite PrepPost, General, structural-mechanics
August 25, 2023 at 12:16 pm
SolutionParticipantTo get an ASCII table for any results inside ANSYS Composite PrepPost product, you need: Step 1/5: Create an empty ASCII file, for example “acp_export.csv” Step 2/5: Right mouse button on “Solution” and select “Export Results…” see screenshot in attachment Step 3/5: On the “Path” field, select the “acp_export.csv” previously created Step 4/5: One the “Definition” field, select the result of your choice from the drop-down menu Step 5/5: On the “Entities” field, select the Element Sets of your choice
