January 25, 2023 at 7:17 am
FAQParticipantFirst of all, collecting per-injection per-thread of discrete particle information has to be enabled. This can be done via the TUI command “dpm-zone-summaries-per-injection?” under the TUI main menu “report”. After you’ve enabled that, you need to run the solver (including at least one DPM iteration) in order to actually collect information that way. Only information collected after you’ve enabled the per-injection per-thread summaries will show up in the summary the way you expect it. The output can be directed to file through the TUI command “dpm-extended-summary” under the TUI main menu “report”. This is underlined below: /report> dpm-extended-summary Do you want to write the summary to a file? [no] yes filename (*.sum) [“”] test Do you want to pick one injection? [no] yes Injection name> injection-0 Injection name> injection-0 Saving summary report to file: test Note: Fluent doesn’t append file extensions like *.sum automatically.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
