Tagged: 18.2, CFX Turbo, CFX-TurboGrid, fluid-dynamics, General
June 5, 2023 at 7:05 am
FAQ
ParticipantThe error “V value outside of its bounds…” can sometimes be due to the blade having a cut-off trailing edge but having the “Cut-off or square” check-box under Blade Set > Blade > Trailing Edge Definition in TurboGrid not being checked. Checking this box should correct the error.
- Skewness in ANSYS Meshing
- ANSYS Fluent: Introduction to the GEKO Turbulence Model Part I
