Tagged: 19.2, cfx, fluid-dynamics, General - CFX, General CFX. restart
May 15, 2023 at 8:32 am
Solution
ParticipantWhen selecting a res-file in the CFX Solver Manager for defining a new solver run, you might obtain the following error message: Error reported by IO module: create_indextable: stored index is wrong: missing start tag This error message indicates an issue when the res-file was written, i.e. disc space error, file system glitch etc.., which resulted in a corrupted file index table. It might be possible to fix the issue. Please see attached PDF on how to correct this by forcing a re-creation of the index table.
1. 2057501.pdf
- Skewness in ANSYS Meshing
