How to extract spring force and deformation results for springs which are created using apdl commands in workbench mechanical
April 13, 2023 at 7:33 am
Solution
ParticipantThere is userdefined result option to extract these results. Please use SPRINGF and SPRINGU as expression scopping to result Items with element id (spring element id). Please find attached one sample example for your reference.
1. 2060372.zip
