Tagged: 16.2, Designer, Electromagnetics & Electronics, EM Design, Subdesign
May 25, 2023 at 7:30 am
SolutionParticipantFollow the below procedure to to expose the excitations defined in the sub-design to the toplevel design • Double-click on the Top design (EMDesign1) in the Project Manager window (to make it as the active design • Select Sub design in the Layout editor i. Right-click in the Layout editor and select Port > Create Port on Component… • In the Create Ports window i. Select
ii. Click the OK button Ports (Excitations) defined in the Sub design will be exposed to the Top design. Please find the attached pdf document Attachments:
1. 3DLayout_Expose_Ports_from_SubDesign.pdf
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- ANSYS HFSS: Creating 3D Components
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to Set “Non-Model” Property to an Object in 3D Layout
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
- How to Create Bondwires in 3D Layout ?
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
