- All Categories
- Fluids - Postprocessing
- How to export flow results from ANSYS Fluent on domain boundaries in EnSight case Gold format?
Tagged: Ansys Ensight, ansys-fluent, Case Gold format
June 6, 2022 at 8:33 am
FAQParticipantThis is actually possible if one toggles on the ‘EnSight Parallel’ in export dialog after selecting the “EnSight Gold” export format. Note that you can either export solution data from Cell Zones or Surfaces, but you cannot do both at once. Please also note that this export capability is only possible if you are starting parallel (not serial) Fluent. Keywords: EnSight Export, Boundaries, Export, EnSight
- ANSYS Fluent: Scene and Animation Creation
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- How can I hide the legend or colormap for a Fluent plot?
- How do I automatically export figures generated in CFD-Post from Workbench?
- Add Annotation to Graphics Display within Fluent
- How do I display a vector or contour and the mesh lines together via TUI command?
