March 17, 2023 at 2:15 pm
FAQParticipantIn Maxwell electrostatic solver, a new feature calculates the breakdown voltage, which a corona discharge will occur. The user may select the seed locations and the dielectric gas type for further computation. Field line trace overlays allow user to plot E field lines in 3D space and on insulator surfaces, you can invoke the Inception Voltage Evaluation dialog after a field line trace plot has been created.
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
