Tagged: 17, dpm, fluent, fluid-dynamics, Modeling/Setup Advice, MP - Particle Tracking, multiphase
March 17, 2023 at 1:11 pm
SolutionParticipantThe parcel size is important for DEM and DDPM. In DEM simulations parcel size is used for the collision calculations. However in both cases we have to ensure that the volume of the parcel is smaller than the cell volume to ensure an accurate and stable solution. Please see attachment for details on calculating the parcel size Key word: DEM, DDPM, parcel size, time step size, parcel mass
1. 2042424.pdf
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
