March 17, 2023 at 1:11 pm
SolutionParticipantFirstly, the user needs to create two remote points using the contact elements. Afterwards, the user needs to create an element MPC184 between the two remote point. Using the sectype and secjoint command, he should take care of the orientation of the joint and all the others related parameters. You can find an example in attachments.
1. 2040150.zip
2. sol-2040150.pdf
