Tagged: 18.1, color, display, General, material, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQ
ParticipantTo do so first select the “Geometry” branch in the Tree outline, second locate the “Display Style” field in “Details of Geometry” window, then choose “Material” from the drop-down menu. The legend will indicate the color used along with the name of the material. Default colors can be changed in the Outline Pane of the Engineering Data workspace.
