June 6, 2022 at 10:32 amFAQParticipant
The following is a procedure to enable the display of the poor mesh quality of a cell (or face).
1. Go to Display > Grid to open the Display Grid panel
2. Select the Cells (Faces) tab
3. Select Quality from Options
4. Enter the range of quality you want displayed in Cell (Face) Quality range
5. Select an object from Cell (Face) Zones
6. Display
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- How can I create a 2D section from a 3D model in SpaceClaim ?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS Workbench: Decomposition and Hex Meshing – Part II
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- ANSYS ICEM CFD: Basic Blocking
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- ANSYS BladeModeler Overview: Design of a Centrifugal Compressor
- ANSYS ICEM CFD: Swept Multizone Meshing
