April 5, 2023 at 2:32 pm
FAQParticipantTo disable wall contact model use the expert parameter “trilinear advection=f “. This has been used in situations where a given fluid in a multiphase simulation is adhering to a wall (at low volume fractions) at a location it shouldn’t physically be. Using the expert parameter removed the fluid from the wall.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- Guidelines for Courant Number for steady and transient simulation.
