Tagged: 18.2, Electromagnetics & Electronics, General (HFSS), hfss, Other
May 25, 2023 at 7:30 am
SolutionParticipantWhen first start Electronics Desktop after a new installation, user is prompted to enable the Product Improvement Program by a popup menu. Sometimes this feature contradicts the local office policy for software usage. Solution: To disable the ANSYS Product Improvement Program for all users so that each user is not prompted to enable the Program when they first start Electronics Desktop, after installing the software, run the following command as a user with permissions to modify the installed fileset, replacing [2017.2] with the version number, if needed: UpdateRegistry.exe -set -ProductName ElectronicsDesktop[2017.2] -RegistryKey Desktop/Settings/ProjectOptions/ProductImprovementOptStatus -RegistryLevel install -RegistryValue 1 This solution can be found in on-line Help by navigating to Getting Started with ANSYS Electronics Desktop > The ANSYS Electronics Desktop > Top Menu Bar > The ANSYS Product Improvement Program
1. How%20to%20disable%20Ansys%20Product%20Improvement%20Program_.pdf
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
