January 25, 2023 at 7:17 am
FAQParticipantIn output control, create a particle histogram with and x variable=mean particle diameter, y variable=particle number rate, and sample location=outlet. This will write a CSV file representing a histogram showing the instantaneous particle number rate at the outlet for each particle diameter bin. To calculate the net particles leaving the domain over a transient simulation, manually (or using a script) parse through the collection of CSV files written each timestep.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
