Tagged: 19, General, mechanical, structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantIn Solution, click on the result object. At the bottom right corner, select ‘Graphics Annotations’ sheet. This will show list of all the probe annotations added to the window. Select the annotations added for particular result object, right click and select ‘Delete’.
