How to define contact between two acoustic bodies ? How to connect dis-similar acoustic element meshes ? Is there an example for using contact between two acoustic bodies ?
Tagged: 19.2, acoustics, mechanical, structural-mechanics
April 13, 2023 at 7:33 am
SolutionParticipantYes, refer attachments for solution.
1. 2058968.zip
2. Acoustic_Contact_V192.pdf
