June 6, 2022 at 9:57 am
FAQParticipantStep 1: From Tree Outline, click right-mouse-button (RMB) at “Model” and choose “Create a Remote Points”, create a remote point with selected geometry and coordinates.
Step 2: From Tree Outline, RMB at “Geometry” and choose “Point Mass”, choose “Scoping Method” to be “Remote Point” and select the remote point just created, define the mass and inertia for the mass point.
