How to deal with the error message about “You have specified result time (or frequency) = xxxx for a result file which has maximum time (or frequency) = xxxx”.
June 6, 2022 at 9:57 am
FAQParticipantThis error message indicates that the DISPLAY TIME under one of the results in the project exceeds the END TIME of the simulation. Thus, program is not able to plot the results. The DISPLAY TIME is the “specified time (or frequency)” referred in the message while the END TIME is the “maximum time (or frequency)” referred in the message. What user needs to do is to enter 0 at the DISPLAY TIME of the results. Program will re-set the DISPLAY TIME automatically to the END TIME. Thus the results will be plotted by the program and no such error message will appear.
