March 17, 2023 at 8:59 am
FAQParticipantTo use Custom Shortcuts, – Go to File >>Click “SpaceClaim Options” > Customize > Shortcuts – Click Add – In the “Show commands containing” field type in what you would like to do. For example, type in “split” if you would like to create a shortcut for splitting a body. – In the “Command” field make sure to select the correct command from the drop-down list – Assign a shortcut for the command in the “Press new shortcut key” field. – Click Assign
