May 25, 2023 at 7:29 am
SolutionParticipantThis document demonstrates how to create RMxprt efficiency maps plot from Maxwell data report. This feature will allow RMxprt to convert efficiency map date from csv format to rdat format and save them to the user-defined path automatically. After that, Maxwell can draw efficiency maps from “Create Report From File” based on rdat format exported from RMxprt model.
1. 2068008.zip
2. EM_FAQ_RMxprt%20Efficiency%20Maps%20Plot%20from%20Maxwell%20Data%20Report.pdf
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
