Tagged: 2019 R3, General, structural-mechanics, workbench platform
April 13, 2023 at 7:33 am
Solution
ParticipantPlease see the attached sample model and document. The model is created in 2019R3 but the discussed approach can be used in previous versions.
1. Rigid transform and multiple copies.pdf
