Tagged: 18, General, mechanical, modal, prestress, server, structural-mechanics
August 25, 2023 at 12:16 pm
FAQ
ParticipantProcedure to quickly generate *dat file to run prestressed modal analysis in server is attached
1. 2052679.pdf
2. 2052679_1.pdf
