Tagged: 16, fluent, fluid-dynamics, MP - Free Surface Flow, Other, post-processing
March 17, 2023 at 1:11 pm
SolutionParticipantFlow animations can help decipher the transient physics of free surface flows or volume of fluid (VOF) simulations. Two options are available in ANSYS Fluent for creating flow animations: 1. Using Animations Sequences available under Calculation Activities > Solution Animations 2. Saving images periodically using Text-User Interface (TUI) commands (a movie can then be created using a third party software like Windows Movie Maker) The latter method is recommended since it is more stable, flexible and would require lower hard disk space. The attached slides will take you through the steps required to save an animation for a fuel tank filling simulation.
1. 2039574.pdf
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
