March 17, 2023 at 8:59 am
FAQ
ParticipantUsing pull operation to create hole only works for solid geometries. Boolean operations cannot be applied to mixed topology. The right approaches to create a hole on a surface are: 1) Directly create or project closed curves onto the surface 2) Use “Combine†tool to subtract one surface from another.
- How to resolve “Error: Invalid Geometry”?
