April 13, 2023 at 7:33 am
SolutionParticipantTo convert 3D solids into thin shell bodies,use ‘Shell’ operation in SCDM. Please refer to the attachments for the solution. The video was done in a previous version but it is still valid in 2019R1.
1. 2045506.mp4
