How to compute the DPM tracks for 1-way coupled simulation using TUI command without using the Display menu?
March 17, 2023 at 8:59 am
FAQParticipantFor a 1-way coupling DPM simulation, the particle trajectories are computed only during the post processing. In order to avoid to call any Fluent graphical capability, it is possible to execute the TUI command: /solve/dpm-update to update the particle trajectories.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
