February 6, 2023 at 2:42 pm
FAQParticipantBy default, inductances are not computed in the Maxwell solvers to save time. The computation must be specified by the user. In the magnetostatic and eddy current solvers this is under: Maxwell 3D > Parameters > Matrix. In the magnetostatic solver, you can choose apparent or incremental inductance. In the eddy current solver, only apparent inductance can be calculated. In the transient solver this is under: Design Settings > Matrix Computation > Compute Inductance Matrix. Apparent or incremental inductance can be calculated including both the self and mutual components.
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
