March 17, 2023 at 8:59 am
FAQ
ParticipantThis is a setting in the SCDM options. 1) From File, select “SpaceClaim options”. 2) Select “Advanced” on the left-hand side of the window 3) Under “General”, select the language in the drop-down menu on the right-hand side of the window
