March 17, 2023 at 1:12 pm
SolutionParticipantThis document demonstrates how create a halbach array in Maxwell, which is a special arrangement of permanent magnets that makes the magnetic field on one side of the array stronger and virtually eliminates the field on the other side. Maxwell an easily model this arrangement in it’s possible variation.
1. 2063888.zip
2. EM_FAQ_HalbachArrayMaxwell.pdf
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
