General
General
How to bond a line body to a face of a solid body
    • FAQFAQ
      Participant
      A Body Interaction object can be inserted under Body Interactions to bond a line body and a solid body. The Body Interaction object is scoped to the line body and the solid body. Its Type is set to Bonded. Make sure the Maximum Offset is large enough to exceed the distance between the line body and the nearest face of the solid body. This should connect the line body to the solid body. The Break can be set to Stress Criteria to simulate the breakable bond.
