January 25, 2023 at 7:17 am
FAQParticipantWhen the particle collision-breakup model is used, streams with insignificant mass or numbers in parcel are deleted. It is possible to decrease the minimum mass or number of particles in parcel. Use the text user interface commands, (rpsetvar ‘dpm/minimum-parcel-mass 1e-25) and (rpsetvar ‘dpm/minimum-parcel-number 2) I have checked these for Fluent 6.1.22 in Linux platform. Copy and paste these commands as they are in the main Fluent console. You might change the values that I have specified.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
