May 11, 2023 at 1:02 pm
Solution
ParticipantThis document demonstrates a new feature of nonlinear impedance boundary in 2021R2, which is supported in 3D Transient design. Impedance boundary could be used to simulate the effect of induced current in a conductor without explicitly computing them. When setting up the model, the conductor itself must be excluded from the solution region (saving time needed to mesh and solve for currents). Surface loss density field plot is available for calculating loss distribution using this boundary condition.
1. EM_FAQ_NonlinearImpedanceBoundaryfor3DTransientDesign.pdf
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- How to create and manage a queue of simulations?
- What are the available boundary conditions in Maxwell?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- Are solid losses and eddy losses the same in Maxwell?
- How to calculate capacitance and inductance in Maxwell Transient solver?
- How to perform a material sweep?
