Tagged: 18.2, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 amFAQParticipant
One may use Solution Combination to do the same but the models should be linked to each other. You can get more info about it at, ANSYS Help//Mechanical Applications//Mechanical User’s Guide//Using Results//Results Utilities//Solution Combinations
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
