How to activate the Non-Iterative Time Advancement Algorithm (NITA) from ANSYS Fluent Text User Interface?
Tagged: 2019 R1, BCs & Interfaces, DPM; Multiphase, fluent, fluid-dynamics, materials, MP - Particle Tracking, NITA, tui
March 17, 2023 at 8:59 amFAQParticipant
It is intuitive to search for a way to activate the Non-Iterative Time Advancement Algorithm (NITA) under the Text User Interface (TUI) menu “solveâ€. However, under “solve†and precisely under “solve/set/nita-expert-controls/†one can adjust some advanced NITA settings and have access to the new Hybrid NITA framework. In order to activate NITA, one has to go to the “define†menu. Here along with “models†there is an option to enable NITA. In a nutshell: 1/To enable NITA from TUI: /define/models/noniterative-time-advance? Yes 2/To access advanced NITA settings: /solve/set/nita-expert-controls
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Mixing Tank Modeling in ANSYS Fluent
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- What do “incomplete” DPM particle tracks mean?
- Simulation of Exhaust Gas Recirculation (EGR) Cooler with CFD
