June 6, 2022 at 9:58 am
FAQParticipantInternal fluid can be defined through “SECDATA” for pipe elements. Both mass and pressure effects are included. First define the internal fluid density with “MP” command and then refer to this matid in “SECDATA”.
To include internal fluid in Workbench Mechanical, command object will be needed to specify “SECDATA” with internal fluid.
Another option is to use “Offshore ACT” extension, which can be downloaded from ANSYS App Store (accessible from the Ansys.com site)
