March 17, 2023 at 8:59 am
FAQParticipantThe additive manufacturing materials in workbench all have temperature dependent BISO (Bi-linear isotropic material) properties which can be accessed through Engineering Data. Some changes were made to the IN625 and IN718 properties in 19.2 to reflect new Additive Manufacturing property data. Note that IN718, IN625, and Ti64 have been used in the 19.2 Verification Manual problems and have been observed to produce good results.
