How to access the intrinsic position variable for every band. Since every band has an independent motion, is there also an independent position variable?
September 22, 2023 at 11:02 am
SolutionParticipant: Instead of just using “Position”, use the variable “Position1” and “Position2”. These variable names are listed in the properties if you click on the Model category in the project manager. You can use these in combination for any/all motion expressions.
- EM FAQ: How to export the simulation results/plots of Maxwell?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- EM FAQ: How to define project variables that apply to all designs?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- What are the default boundary conditions in different solvers?
- Vacuum Thermal Modeling in ANSYS Icepak
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- ANSYS Icepak: How to delete unused materials in a project?
- EM FAQ: How to link the mesh from a static solver to transient solver in Maxwell?
- ANSYS Icepak: O-grid meshing issues
