How should you set up different wall boundary conditions for different fluids in a CFX multiphase simulation?
Tagged: 19.2, BCs & Interfaces, cfx, fluid-dynamics, materials, MP - Eulerian MP Flow, multiphase
April 5, 2023 at 2:32 pm
FAQParticipantTo be able to select different wall boundary conditions for different fluids, you need to: 1) Edit the wall boundary and open the Boundary Details tab. Set the Mass and Momentum Option to Fluid Dependent. An extra tab, ‘Fluid Values’ will appear. 2) In Fluid Values, you can set up different boundary conditions for different fluids.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
