General
General
How should I use the Properties panel in SCDM?
    • FAQFAQ
      Participant
      The Properties panel shows information about a selected object. Use this panel to view and edit characteristics of an object. In addition to components, surfaces, and solids, you can use the Properties panel to modify property values for sketched objects, inserted images, patterns, and sheet metal.
