General
General
How is joint tolerance CNVTOL,JOINT used in a structural analysis?
    • FAQFAQ
      Participant
      This JOINT tolerance is used to check on satisfaction level of Joint constraint. For example, if it is a universal joint: some of the constraints for node I, J are: UxI = UxJ, UyI = UyJ, UzI = UzJ, During the Newton-Raphson computation, these constraints are ‘exactly” satisfied if || Ui — Uj || < || JOINT tolerance ||, code interprets this as converged.
