May 25, 2023 at 7:29 am
FAQParticipantTo visualize at the same time CAD model and far field report you have to: -> Plot all the far-field data that you want to visualize; -> Right mouse click on “Field overlays” in the Project manager panel (usually on the left side of Electronics Desktop GUI); -> Select Plot Fields->Radiation Field; -> Select as visible all the plots that you want to see; -> Click on “Apply”.
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
