September 22, 2023 at 11:02 am
Solution
ParticipantPlease refer to attachments to access solution
1. 2050724.pdf
2. 2050724.zip
- EM FAQ: How to export the simulation results/plots of Maxwell?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- EM FAQ: How to define project variables that apply to all designs?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- What are the default boundary conditions in different solvers?
- ANSYS Icepak: How to delete unused materials in a project?
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- Vacuum Thermal Modeling in ANSYS Icepak
- ANSYS Icepak: O-grid meshing issues
- ANSYS Icepak: How to model a blower in Icepak?
