How do you implement the instruction recorded in a failed Topology Optimization output? “… You can now relax the violated constraints and restart from the given iterate by entering RELOAD_DENSITY=TRUE”
Tagged: 19, analysis-techniques, mechanical, optimization, structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantThe message is usually triggered because the final iterate does not satisfy all constraints. User can insert a command object in the environment branch with “RELOAD_DENSITY=TRUE” This will enable the topology optimizer to pick up where it left off.
