Tagged: fluent, fluid-dynamics, MP - Particle Tracking, multiphase, Other, transient
March 17, 2023 at 1:11 pm
SolutionParticipantFor a steady-state flow with non-stationary particles (DPM), the calculation summary is as follows: 1.Particles are injected at the set repeat interval in Interaction column, starting an unsteady calculation of the particle only. 2.The trajectory of the particles is calculated upto Particle Time Step Size × Number of Time steps. 3.If the time is greater than the Stop time set in Injection, it stops in the middle of the 4.After particle tracking, the flow calculation is performed. When the next DPM starts, it repeats Steps 1 to 3. It should be noted here that the particles are tracked unsteady, like a real unsteady calculation, because the data at each time is not stored. Each particle state cannot be displayed. If there be the cause, in most cases, we recommend that you also calculate a non-stationary flow field.
1. 2043362.pdf
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- Guidelines for Courant Number for steady and transient simulation.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
