March 17, 2023 at 1:11 pm
SolutionParticipantIf you want to modify the criteria for film separation in a liquid film model, change the notch angle with the following TUI command: / define / models / dpm / options / film-separation-angle 60 Please refer to the documentation listed below for further details: ANSYS Fluent 16.2 User’s Guide – 24.4.1 Discrete Phase Boundary Condition Types ANSYS Fluent 16.2 theory Guide – 16.7.4 Separation Criteria
1. 2041733.pdf
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
