- All Categories
- Fluids - Postprocessing
- How do I save a View?
June 6, 2022 at 8:33 am
FAQParticipantBy clicking Viewing–>Views, it is possible to change the camera settings. To save the View settings after certain view angle is chosen, click Save under Action. Specify a name for the View file that will be written. It can now be selected in the View field. The View file can be read also in other case files and is useful for comparing results. To read the View file in a separate case, click Read (found under Action) and select the file.
- ANSYS Fluent: Scene and Animation Creation
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- How can I hide the legend or colormap for a Fluent plot?
- Add Annotation to Graphics Display within Fluent
- How do I automatically export figures generated in CFD-Post from Workbench?
- How do I display a vector or contour and the mesh lines together via TUI command?
