June 6, 2022 at 9:58 am
FAQParticipantYou may also observe that KeyShot opens, but no further action occurs.
The following items might be missing which would cause the link to KeyShot to fail
1. There are 2 environment variables that get created in Windows upon installing KeyShot:
KEYSHOT_EXTERNAL_LICENSE_FOLDER=C:Program FilesSpaceClaim
This one typically points to the SpaceClaim installation directory if you’ve purchased your KeyShot capability through us.KEYSHOT6=C:UsersPublicDocumentsKeyShot 6
Make sure both of those are present and linked to the correct locations.2. Add the following programs to Firewall exceptions
C:Program FilesKeyShot6binkeyshot_daemon.exe
C:Program FilesKeyShot6binkeyshot6.exe3. If you are still encountering problem, then it is suggested to reinstall Keyshot and/or SpaceClaim.
– Please be sure to run the Setup by Right-click > Run As Administrator.
– Disable any anti-virus or blocking programs as needed during installation.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- ANSYS Mechanical: Node Move
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
